Hey guys appreciate any help with troubleshooting!! My maytag washer seems to only be draining in the spin cycle when i slam the door before starting the load. Not sure what can cause this any help would be great !! fyi just installed a new drain pump. still having issue
Check the door latch switches. Make sure they are properly engaged when the door closed. Never slam the door.
Here are the breakdown diagrams and Replacement parts for Maytag MAH4000AWQ WASHER- HORIZONTAL AXIS | AppliancePartsPros.com
thanks gene i will check that out the door lock is engaging for some reason i think it might be a short, i heard similar issues i just don’t know what part to replace
