Maytag NO HEAT
Gas Dryer tumbles but no heat. What should I check for?
First check for continuity in your thermal fuses and thermostats.
If they all check out, you probably have a problem in your gas ignition/flow system.
Here is the service manual
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Good luck and let us know what you find.
I tested the fuse and flame sensor…good. I removed the igniter and applied 110v direct to it and it didn’t warm. I then replaced the igniter and system is working correctly.
Thanks for the feed back!
Great, glad you got it fixed, and thanks for updating us.
