Maytag Neptune
:confused: Washer is just under 2 years old. During the wash cycle, the washer stops, and we get an error code of nF. Have checked the water lines and they are not clogged up. Called repair, can’t come for 1 week. Any help you can give me is appreciated. Tx
NF means no fill, continuous fill of 12 mins. generates this. check water valves and hoses. if you do actually have proper water flow in and are getting this then check level sensor. a full tech sheet is avail at servicematters.com with info on checking components.
