My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its enclosure( I can hear the water in there when I turn drum by hand).
There may well be an obstruction in the internal drain hoses and/or the pump. Check them out as a first step.
If they are ok, the problem may be a failing pump.
Would that cause the machine not to work properly as far as the amount of time the washer spins?
Here is the service manual for your neptune. It may help you troubleshoot the problem.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=1
[SIZE=3]Mike,[/SIZE]
[SIZE=3]I have the same problem. My washer is 11 years old, purchased 5/8/01. I have a musty smell when I don’t use the machine for a few days. no setting seems to fully empty the water under the drum. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]What did you do to repair? [/SIZE]
[SIZE=3]thank you [/SIZE]
