I have a maytag nepyune front load washer leaks water out the front door!
a little stream at first then a couple then gushes! had it serviced they put in all gaskets and seals and the big rubber drain surround between the tub and the front!!
:mad: :eek:
Assuming you used a reputable service firm, get them back and get them to fix it.
I would also check to make sure it is not over filling machine. Normally, the water level is so low that it should not even come out the door. The water level detector could be starting to fail. See neptune washer for more Neptune tips…
Until next time…
