HI,
What is the reputation of the Maytag Neptune line? I do not know there age, am am considering buying them. Are the worth buying used? The models specifically are:
Maytag Neptune washer (MAH7500AWW) and Maytag Neptune dryer (MDE7500AYW) The craigslist link is below:
They are priced too high. Probably more tha 8 years old, about the time the tub bearings go bad in the washer. If you can hear/feal the tub bearings when you manually spin the basket, that confirms it.
I’m kind of a newbie too in the whole washing machine buying category so I need a little bit of help here! I want a nice washer but I also don’t want to spend a billion dollars (doesn’t everybody?) So I was hoping for a little advice and suggestions about buying a little bit cheaper washer that’s still pretty high quality if that makes sense. I found this site Front Load vs Top Load Washers 2013 Review and it was good to read some information about each washer. I’m thinking about buying the LG WT5070 but i’m not sure if that’s the best washer for the price. Any help or suggestions would be great, thanks guys.
