Maytag Neptune Waser
My washer will not spin, so i checked out drain hose and intake hoses, the washer did go off balance and the code dc came did up the first and only time. so i took all the cloths out and than start the washer on a new cycle nothing in it no weight and it ran fine with no codes and completed a full wash. so we loaded it again and now it stops again before it starts the spin with out any codes. ??? Please Help Kevin
[FONT=Calibri][SIZE=3][COLOR=#000000]Kevin,[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]If your console looks like the Pic below then the issue is more than likely a Clutch Pulley issue.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]If you machine is a FAV6800A console pic below or a FAV9800A the LCD flavor of the machine then read thru this post and see if it helps; [/COLOR][/SIZE][/FONT][COLOR=#333333]Maytag Neptune load unbalance[/COLOR]
[FONT=Calibri][SIZE=3][COLOR=#000000]Try to post your model number that will help us. Right now I’m going on your failure description which is a classic failure for the Maytag TL models above………….Dick[/COLOR][/SIZE][/FONT]
My Pic.JPG (24.1 KB)
