Hello, I am having a problem with the controls on my Maytag Neptune Front load washer model mah5500bww serial b5731742gl. The controls will light up but when you push one of the function buttons it will either just beep or it will switch to the selected function then turn back to another function. Also when you press start it does nothing but beep non-stop and no codes will show up on the led display. Tried to go into the service mode to test functions but it will not even do that. Any suggestion please ?? Thanks.
If you cannot get it to go into service mode then the control unit is likely the problem.
