Gas Dryer igniter goes on, then after 5 mins shuts off. The igniter gets red, calls for heat and then flames up.
After 5 mins, flame stops. After 3 more mins, the igniter gets red again but no flaming. Igniter is red for only about 15 secs only. Does same thing a minute later.
Unit runs fine but without any heat.
At first, I though it was the coil valve solenoids that need replacing, then a guy in parts store said it could be one of the 2 thermostats. Tried making connection touching both terminals on thermostat part #306910 to see if I could get flame to go on bypassing thermostat but it did not work.
Does that mean it is that thermostat or is it coil valve solenoid(s)279834 or even the 4 prong thermostat #303395
House full of guests this July 4th and need dryer. Need Help
The cause of the problem you described has nothing to do with any thermostats. It can be a bad gas valve coils (most likely) or a bad gas valve itself (very rare).
Here are the breakdown diagrams and Replacement parts for MAYTAG MDG3000AWW DRYER- GAS | AppliancePartsPros.com
It was the coil kit…thanks Gene
may tag mdg3000aww ,drum still run but not heat at all.what is the part need to check ???
You may want to start the troubleshooting from checking the thermal fuse (#10 on the diagram) for continuity.
- The thermal fuse AP6007940
We found this thread and ordered the part; it solved our problem for $15. Last repair on this dryer (which was not the first) cost almost $300 for similar issue. THANKS SO MUCH!
[quote=Gene;477110]The cause of the problem you described has nothing to do with any thermostats. It can be a bad gas valve coils (most likely) or a bad gas valve itself (very rare).
Gene.[/quote]
