Maytag Neptune Frontloader
The washer has been sounding very loud when spinning out and now the drum seems real loose. Do you think we could buy parts to fix this problem or not? My husband was going to disassemble it to see just what is wrong with it but I said I would ask a question to see if you would know what the problem might be. Thank you for your time.
Please check your model number.
Are you sure it is MAH550BWW and not MAH5500BWW.
Sounds like the tub rear bearing is shot.
They can be replaced but it is a real pain.
Below is some info on doing this.
http://forum.appliancepartspros.com/washer-repair/57726-neptune-bearing-repair-pic-tutorial.html?highlight=neptune+replace+bearing
Yes I made a mistake in my typing and the Model # is MAH5500BWW. Thank you so much for the information and my husband said he will try and fix the rear bearing and also thank your for the information on how to do it.:slight_smile:
You are welcomew.
You can probably find some videos on this on youtube as it is a common problem.
