Maytag Neptune Frontload
For some time now, I have been noticing that the Fabric Softener has been watered down and never completely empties. So I just add more softener to the watered down, from the previous load.
I went ahead and cleaned out the bin and took a look at the water holes and all look clean. Guess my main question, does the fabric softener “bin” supposed to empty all the way? Or what I am seeing seems correct? Thank you for your assistance forum connections.
Cold water during the rinse cycle should cycle through the fabric softener tray and empty it. Now fabric softener tends to clog things up so that is the most likely problem which can be fixed by cleaning out the lines. It may be that the cold water valve in not operating correctly in which case it will have to be replaced, but in that case you may just want to live with it.
Thank you. I have the top off. When you say clean out the line from gumming up, it looks to be a larger 1-2 inch rubber flex. Is that what you mean by “line?”
The line or tube going into the tub.
