Brand:maytag neptune
Model Number:mah8700aww
Main Symptom:not sending signal to drain pump
What happens & when:all is well until it gets to 9min. and should drain but nothing, no sounds, replaced pump motor already, it looked good. Blew air thru pressure sensor line, can’t find a reset procedure.
Error Code (if any):nd
Parts or tests already tried:see above
