I have a Maytag MVWB765FW washer. When I turn it on and start the cycle “the sensing” starts and runs about 10 seconds then the washer shuts down (powers off). There was no loud CLICK when the lid should lock. I found the service manual and got into diagnostics mode and am seeing a (Originally I wrote F2E2, that was wrong it’s) F5 E2 which seems to be a lid lock error. Is it as simple a fix as that, replacing the lock or could there be something else causing that error?
I did try to fakeout/bypass the lid down with a magnet which seemed to work because it let me start a cycle with the lid up but the same problem occurred, 10 seconds, no loud CLICK, no water, then power shutdown.
temp/soil/deepfill is what accessed the menu. The “top 3” do not but the buttons function fine.
Is there any way to bypass the bad switch while waiting for a replacement part?The magnet trick doesn’t seem to do it.
Thanks for the pictures and the detailed explanation! Your full model number is MVWB765FW0.
Before replacing the lid lock, there’s an important distinction with the error code you’re getting:
F2E2: User interface communication error.
F5E1: Lid switch fault.
F5E2: Lid lock fault.
F5E3: Lid unlock fault.
The fact that the washer completely powers off after about 10 seconds makes me more suspicious of a communication issue between the user interface and the main control board than a defective lid lock alone.
The magnet may allow the control to recognize that the lid is closed, but it cannot provide confirmation that the lid has physically locked. There isn’t a safe way to bypass the locking mechanism to continue using the washer.
Here’s what I would check before ordering parts
1. Verify the error code.
I checked the available service literature, and the older technical sheet associated with your model does not list F2E2. Other Maytag platforms identify it as a user interface communication fault. Double-check whether you’re actually seeing F5E2, which would fit your symptoms very well.
doityourself.com+1
2. Inspect the lid strike and lock.
Remove the magnet and unplug the washer.
Check the lid strike for cracks, damage or misalignment.
Inspect the lock mechanism for detergent buildup or anything preventing it from moving.
Check the wiring between the lid lock and the main control board for loose connections or damaged wires.
3. Run the lid lock diagnostic test.
Using your service manual, enter the component activation mode and command the lid to lock.
If the lid locks normally, the lock assembly may not be the problem.
If it doesn’t lock, perform the resistance checks outlined in Test #8 – Lid Lock.
If the lock and wiring pass their tests, the main control board may not be supplying power to the lock.
4. Check the user interface.
Since temperature, soil level and deep fill allowed you to enter diagnostics, run the keypad activation test to verify that all buttons register properly. With the washer unplugged, also inspect and reseat the connections between the user interface and main control board.
A couple of questions
Does the lid lock indicator flash at all before the washer shuts down?
When the washer shuts down, can you immediately turn it back on without unplugging it?
Can you confirm whether the display alternates between F2 and E2 or F5 and E2?
I wouldn’t rule out the lid lock just yet. A failed lid lock can also cause this particular model to shut down shortly after starting. I’d like to confirm the error code and test the lock before having you spend money on replacement parts.
No worries! That makes a lot more sense. F5E2 is indeed a lid lock error.
That’s a great troubleshooting result. Since the washer started with an external magnet but fails with the lid closed normally, I would suspect the lid magnet, its alignment with the lock assembly, or the magnetic sensor inside the lid lock.
Just because the original lid magnet attracts metal doesn’t necessarily mean it’s strong enough to activate the sensor properly.
Before ordering the lid lock, I would check the following:
Make sure the original magnet is securely mounted and hasn’t shifted.
Check the lid hinges for damage or excessive play.
Make sure the lid sits flush with the washer top.
Clean the lid lock opening and inspect it for anything obstructing the locking mechanism.
With the magnet removed and the lid closed normally, apply gentle downward pressure near the lock while starting a cycle. If it works, you likely have an alignment issue.
The service manual specifically lists lid interference, an undetected closed lid, and failure to confirm the locked position as possible causes of F5E2.
doityourself.com+1
If everything lines up properly, I’d lean toward replacing the lid lock assembly. The internal magnetic sensor could be failing or becoming less sensitive.
Your test makes the main control board much less suspicious, although it doesn’t conclusively rule it out or confirm which component has failed.
Please don’t continue operating the washer with the external magnet in place, as this defeats an important safety feature.
Thank you again for the speedy replies. I figure if I am replacing the lid lock I may as well replace the strike magnet in the lid itself as well although I don’t see any obvious screws holding it on. I didn’t notice that in the parts list here. Is it replaceable or only with the whole lid?
LOL, thanks. If that’s problem I’d just replace the washer! I’ll order the Lid lock Monday morning since it won’t ship till then anyway. Seems the odds are in my favor for it being that.
