Maytag MVW7232HW1
Brand: maytag
Model Number: mvw7232hw1
Main Symptom: won’t leave Sensing cycle
What happens & when: won’t shift out of sensing cycle
The most common fix for this problem is the clutch. I ordered the clutch (W10754448) from Appliance Parts Pros. We believe the part is bad because a multimeter reads “OL” on the contacts. Customer service didn’t respond to an online message for a full day, then I called in and was informed I have to post on here before I can return the bad part. We’ve always had good luck ordering from you all, but will have to look at other vendors.
Hi, good morning! Sorry to hear that happened. I know it can be frustrating, especially when you’re just trying to get some clean clothes. I’ll try my best to help you out.
Did you receive any error codes from the washer? If so, send them over and that may help me narrow down the issue and give you the right steps to check next.
The goal is to test the clutch I purchased to see if you all did send me a bad part. Customer service told me to check here for instructions on how to test the clutch and won’t offer a return or refund until I get that answer. The multimeter shows no resistance in the clutch sent to me.
Hi, an OL (Open Loop) reading on your multimeter means the electromagnetic clutch coil has an open circuit and will need to be replaced.
A good clutch should normally show resistance across the coil terminals, roughly 1.75–15 ohms, depending on the exact clutch.
Since yours is reading OL, the internal winding has most likely burned or broken open. This prevents electrical current from flowing through the coil, so the clutch cannot engage.
At this point, I would recommend replacing the electromagnetic clutch.
Thank you. The OL reading is coming from the part sent to me by Appliance Parts Pros. Maybe customer service will issue the refund now that we have verified it is bad.
