Maytag MVW7232HW0 Will Not Complete a Cycle
Brand: Maytag
Model Number: MVW7232HW0
I have a 2-year-old Maytag MVW7232HW0 that recently stopped putting out water. This issue required a Main Control Board, a new Slider, and Reset Procedure.
Now every cycle goes like clockwork until it gets to the final spin, leaving anywhere from 12 - 21 minutes (depending on cycle) with a slow spin, lasting indefinitely. I can cancel the cycle and use Drain & with a fast spin for a temporary bypass, but even this cycle will get to 17 minutes and spin indefinitely. No Errors.
What now? Any help is greatly appreciated.
FIXED:
I managed to fix the issue with my machine. If you have a “Smart Wahser,” you might try this. I reconnected the washer to the WIFI and updated the software. Ran a load on Delicate, and the cycle completed as it should. I then ran a moderately sized load on Regular, and the cycle completed as it should.
[quote=JNN1988;926378]Brand: Maytag
What now? Any help is greatly appreciated.[/quote]
