Maytag, MVW7230HC0, Drum engagement during wash cycle
Brand:Maytag
Model Number: MVW7230HC0
Main Symptom:Drum engagement during wash cycle
Error Code (if any):F7E3
Parts or tests already tried: Gearcase, clutch, clutch actuator
I am going to need more information as to what is happening with your washer. Are you getting any error codes. You should be able to run a diagnostic on this model and pull up error codes.
Diagnostic code F7E3. When washer tries to go into wash cycle, it just makes a real loud clunking/clicking noise.
Original problem was the gear case making a grinding noise, and the washer was stuck in sensing mode. Replaced gear case, washer was quiet but still stuck in sensing mode. Found agitator was working, but drum wasn’t spinning . Replaced clutch actuator and clutch kit. Washer would come out of sensing mode now, but when it goes into wash mode it makes a clicking/clunking noise then it cancels cycle.
