Maytag msf25d2eas01 Condenser fan falling off shaft
Brand: Maytag
Model Number: msf25d2eas01
Main Symptom: condenser fan falling off shaft
What happens & when: loud noise, fan not staying on the shaft
Check the fan, if it is loose on the shaft replace it. Check the motor to see if the noise is from it, if so replace it.
Do I need to replace just the fan or the motor and fan?
The fan keeps sliding off the shaft.
With the issue as described, I would replace both.
Got it. Just ordered the kit, it should be in tomorrow. Thank you so much!
Thanks for your question, and you’re welcome.
