I have a maytag gas dryer. Is making a pretty loud screeching noise
While running. I disassembled the dryer and thought maybe it was the
Rear roller wheels. I replaced them as well as the bely while I was in
There. That didn’t stop it. Disassembled again and reached in the blower
To turn the motor shaft. That’s where it’s coming from. My question is, do I need to replace the whole motor? Or is there a bearing/bushing or something I can just replace? Thanks.
[QUOTE=Rwchet;849822]I have a maytag gas dryer. Is making a pretty loud screeching noise
To turn the motor shaft. That’s where it’s coming from. My question is, do I need to replace the whole motor? Or is there a bearing/bushing or something I can just replace? Thanks. MAYTAG DRYER LD69304AAEE
BONN96
Nothing comes up for the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
You will have to replace the motor.
