Thank you for the insightful reply, and possible remedies. For your additional knowledge, this S/S fridge/freezer was installed in Feb 1999, in a home I bought in Sep 2002, which was built in 1996. I realized why they left it, only after pulling it out a couple of months later to clean the condenser fan and what not. It was clear, either their previous, (or this fridge) leaked water, and mildly damaged the wood flooring; and they didn’t want it to be a noticeable point of contention with the sale. No bother, it’s mine now. I’ve had to replace the adaptive defrost control twice; (1st) 2007, (2nd) 2011. Other than those two instances I’ve not had any other service issues, other than routine maintenance I do myself. The first steps you suggested require a bit more time to perform than I have right now, so jumped directly to your questions…with responses below.
A couple of questions that will help confirm the diagnosis:
When the ice maker reaches the fill portion of the cycle, do you hear the water valve buzz for about 5–7 seconds? No.
Is the fill tube above the ice maker clear or frozen solid? I can’t see the fill tube, as it is covered by a flexible shroud type of tube, which I presume helps to keep it from freezing. In the past, (and now), if I suspect the issue is a frozen supply line, I attempt to thaw it by use of a heat gun on low to moderate heat. Has always worked well, when that was the problem. I did notice however, when looking at the water lines on the back of the fridge earlier today, the line supplying the ice maker appears to have about a ¾” air gap at the top, right before it enters the back of the freezer.
If you manually pour about 2/3 cup of water into the ice mold, does it freeze and harvest those cubes normally, or does it continue to spin continuously without stopping? After trying this, the ice maker made one full cycle, (keep in mind, in its current state this only takes 3 minutes), then stopped / froze up, way before where it should have, and did not harvest any ice. However, there were cubes formed waiting to be ejected, but again to no avail. I defrosted everything again, ice maker just kept running it’s 3 min cycle, and is now “frozen / stopped” in this state, without any additional water being added.
I appreciate the help/advice.
