Maytag microwave Mod UMC 5200 BAS lights up, turmntable works but doesn’t heat.
Does it make any unusual noise?
Here are the breakdown diagrams and Replacement parts for Maytag UMC5200BAS MWAVE- CNTRTP / STAND ALONE | AppliancePartsPros.com
Problem was failed connector on xfmr secondary; it holds 2 black wires. Small slip-on connector came loose from male spade; heat from probable arcing left residue on connector and spade. reconnected/soldered wires to connector; connector to spade and all OK.
Thank you; I will keep your contact information on file.
Jack Stevens, Bryan Texas
I’m glad you were able to fix it. Thank you for the feed back.
