Maytag MFX2876DRM02 Door Ajar light issue
Brand: Maytag
Model Number: MFX2876DRM02
Main Symptom: door ajar light on, only one internal light working (bottom shelf), middle drawer function panel is not lighting up nor is middle drawer light. also possibly related, I have been noticing gasket condensation especially on the top of the drawer and around bottom of refrigerator door seals.
What happens & when: when I open the door, only the bottom shelf light comes on. When I open the door and press the door switch (either side), the lights go out properly. When I depress the switches, only the bottom shelf light comes on. The drawer lights never come on. Doors are not ajar, are flush, seem to be sealed tight. No other issues or power surges/flashes prior to the issue happening. Ice and water do not work as the unit believes the doors are open. They make the error ding as always when door was open and someone tries to get ice/water.
Error Code (if any): none, only door ajar light staying on constantly constantly.
Parts or tests already tried: door switch test.
Use the tech sheet and place the unit into service diagnostic mode. Run Test 11, 12 16 & 17
These are for the lights and the door switch.
Pages from tech-sheet-W10811273-RevB.pdf (1.2 MB)
What do I do after running those diagnostic tests?
Through running the test you should locate an error code pointing to the issue at hand, and telling you what needs to be repaired or replaced.
I’m not even sure what “running diagnostic tests” means based on the spec sheet. I entered diagnostic mode and switch 3 did nothing.
The same light came on when each door was opened during diagnostic mode.
The door ajar lights remains on constantly, not flashing, and I have been getting condensation around the seals recently. I’m not sure if the unit is not staying as cool bc it thinks the door is open, or if this could be a larger issue?
