Brand:Maytag
Model Number:MFW9600SQ1
Main Symptom:F 14 code
What happens & when:Suring cycle
Error Code (if any):F 14
Parts or tests already tried: wire harness condition, connections, motor ohm test
F 14 code appeared and stopped washer. Did standard unplug for 15 minutes and plug back in. Problem came back. Unplugged washer, cleaned drain, disconnected water lines and check for debris removed technician pamflet and followed trouble shooting guide. F 14 lead me to motor and MCU. Put through diagnostic procedure C1-C8 and water fills and drain only worked. Drum did not spin. Motor shaft spins free, drum spins free, checked wire harness and plugs with no change. Removed motor plug tested motor pins 1-2, 1-3,2-3 all at 6.2 ohms. During diagnostic test when drum should be turning just heard slight clicking from MCU. I have ordered an MCU but not 100% this is the problem. Any additional testing that should be done. One thing is I would like to test is voltages at the plugs of MCU but drawing does not indicate what pins should have what voltage and AC/DC. Any help would be much appreciated.
