You probably have a hard starting compressor. Remove the back panel and check the compressor, if very hot, you either have a system problem, clogged condenser, or a failing compressor, an amprobe and guages would confirm.
hi richappy,
Can you provide some pointers so that I can order parts for a DYI?
What can I do to sort out whether this is :
[LEFT][COLOR=#000000]system problem, clogged condenser, or a failing compressor?
[/COLOR][/LEFT]
I have no amprobe and but have a multimeter . I have taken some measurements between the relay /overload with capacitor between the old and new one and observed no noticeable difference when measuring resistance between C/S/R terminals.
And so I cannot conclude that this is a relay issue .Unless there is new one out there that can help alleviate this issue.
thanks
Give us the part # you replaced, It may have failed.
Whirlpool Overload / Relay With Capacitor 67005560
added the picture of the part that I replaced.
Could this replacement part also bad. Man, what a bad luck if indeed it really is
Pull off the start device. There are a triangle of compressor round pins on the device. The bottom two pins are the start and run pins. Measure across them, resistance should be between 4 and 7 ohms at room temperature. If open, the internal ptc device blew open. If so, get a new one and add a 1000 joule surge protector to the wall outlet, if good, your compressor is probably bad.
so you are saying , if the PTC is bad, I can replace it:
questions:
How does the PTC look like? Ist attached to the compressor ?is it easy to remove ? do you know the part number for that PTC for the refrigerator I am having issues with?
thanks again
It’s inside the black start device you used, just pry it off and do the measurement.
so I measured the resistance between the bottom pins s-r:
12.5 ohm
and between
s-c= 5.6 ohm
r-c= 4.2 ohm
Measure between the bottom two pins on the START DEVICE, not the compressor.
So I took some measurments as suggested:
start -run =12.5 ohm
start-C= 4.5 ohm
run- C= 5.6 ohm
Can you help conclude?
thanks
oops. repost, I will take the measurement on the start device and report later
Remove the start device from the compressor. There is a triangle configuration of pins with two of them side by side, measure the resistance between them, if open, you have a bad start device, just order a new one on this site.
