Brand: maytag
Model Number: mer6765bas
Main Symptom: replaced bake element in oven, still not heating
Parts or tests already tried: old element burned out, new element not heating
Is the broil working in that section, and do bake and broil work in the other oven section?
Bake and broil work in the upper oven. bake and broil do not work in the lower oven.
Check the resistance value of the temp sensor AP4009009 in the lower oven, should read around 1.08k-1.1k ohms at room temp, and check the lower bake/broil circuits from the control board to verify the wiring isn’t damaged, each of those should read about 15-25 ohms. If that’s good you’re most likely looking at a bad control board AP5957887.
I’ve attached the tech sheet for this model to reference for testing at the control board.
techsheet-16027359.pdf (595.7 KB)
https://www.appliancepartspros.com/whirlpool-oven-temperature-sensor-12001656-ap4009009.html
https://www.appliancepartspros.com/kitchenaid-cntrl-elec-w10769079-ap5957887.html
