Maytag mah 8700 aww door switch assembly
How do you replace the door switch assembly on a maytag mah 8700 aww front load washer?
You have to remove the top panel first. Then remove the dispenser drawer and the front panel.
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for Maytag MAH8700AWW WASHER- HORIZONTAL AXIS | AppliancePartsPros.com
Top panel removal.pdf (97.4 KB)
Front panel - door lock removal.pdf (233.0 KB)
