Maytag machine impeller/wash plate spins very fast
Maytag bravos machine giving an unsolvable issue. Noticed clothes were coming out soaking wet after running the drain and spin setting I seen that the impeller/wash plate spins very fast freely from the washer drum which is throwing off the balance of the whole drum and preventing it from spinning properly looked on multiple forms and cannot find a solution the wash plate doesn’t seem loose and no parts seem broken
If the machine keeps going out of balance, it probably has a worn out suspension spring and rod assembly. They need to be replaced as a set, and are available as a set of 4. Part number is W11027174. If nothing else seems broken or worn, I would replace the suspension spring and rod assemblies and go from there…
Ken’s Appliance Repair
How can you explain the impeller / wash plate constantly spinning on any setting the only reason for the drum going off balence is the impeller constantly spinning
