Maytag Icemaker
Icemaker will not push ice out. It makes ice and if I hold the inner door it will push the ice out but using a cup on the door doesn’t work. I believe its a connection issue with the push bar, not sure.
Jireh, You’re most likely correct its a linkage or mounting bracket issue. You’ll need to access the internal bracket assembly and check for brokrn or damaged components.
Here’s a little help.
Good Luck and Thanks,
[ATTACH]5703[/ATTACH]
Binder1.pdf (144.4 KB)
