Maytag Gemini Error Code F3-1 Not heating
First the upper oven stopped heating… We turned the breaker was off all night. Today the bottom oven would also not heat… so now neither will heat or broil We got the code F3-1 and call for authorized servicer
Parts for Maytag MER6770AAW Range - AppliancePartsPros.com
Here is a link to a service manual.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=390
Looks like a oven sensor error.
Check the sensor with a meter.
Should be around 1100 degrees at room temperature.
If not replace it.
If OK then it is probably a control board problem.
Thanks for the help… It started with the upper Oven then the lower Oven the next day… so both sensors? What kind of meter do I need to have to test that? I have a small volt meter…
[COLOR=“Blue”]It started with the upper Oven then the lower Oven the next day… so both sensors? [/COLOR]
This sounds more like a control board problem as it is unlikely that both sensors would go bad at the same time.
Try turning the breaker off for a couple minutes just to see what happens re: does it reset etc.
[COLOR=“Blue”]
What kind of meter do I need to have to test that? I have a small volt meter…[/COLOR]
If the meter has a resistance scale that measures from 0 to 2000 ohms or higher it should do the job.
Below is a link to info on doing this.
Check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
Also my usual blurb on meter usage follows.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Thanks for all the help… Got the manual and all the codes we get talk about the upper oven… F1-1 And F3-1… both saying to check that sensor… my question is would that sensor cause the control board to stop controlling both ovens? That is how is seems now… Should I test and replace that sensor before I do anything with the expensive Oven Control Board?
I am not sure.
Could be that an error like this will shut down both ovens.
I would start by checking the sensor.
