Maytag Gemini Double oven. Had a small fire in lower oven and then those elements stopped working. Three weeks later had a small fire (melted cheese) in the top oven and now those elements won’t work. Anyone know a fix before I go spend a fortune on a repair man?
A Model Number may help other help you.
Often ovens have a thermal cut-off depending on the size of the fire this may be open.
Part # MER6755AAB/Q/S/W
Thanks. If that is the case how would you close/fix?
Replacement parts for MAYTAG MER6755AAB | AppliancePartsPros.com
Here is a tech sheet and manual
http://www.servicematters.com/maytag_library/docs/16023459.pdf
http://www.servicematters.com/maytag_library/docs/16023416.pdf
I only see one thermal cutout and that is for the upper oven’s broil element so that should not kill all elements.
I am assuming that the stove top elements all run OK, if not you may have a power problem.
Try turning the breaker off/on slowly a couple times.
Try to run the diagnostics perhaps that will help narrow it down.
