Maytag Gas Stove
Just had to replace a front burner unit that rusted out. Now if I turn on either front burner the burners light but gas is leaking (smells awful:eek: ). Looks like the tube that goes from the front of stove to burners is cracked/broken. A non-Maytag dealer told me the part for that is discontinued. Stove is just under 10 years old. Is the part below what I would need for replacement? :confused:
Tubing, regulator/pipe(
Part Number: AP4095314
made by WHIRLPOOL Tubing, regulator/pipe(
made by WHIRLPOOL
Thought someone was to answer this within a day. Help
Looks like you need the fitting and orifice assembly (#16 on the diagram).
It is very important to remove the burners (by turning them CCW) and the screws under the burners prior to lift the top panel up.
Here are the breakdown diagrams and Replacement parts for MAYTAG MGR5750ADW | AppliancePartsPros.com
