Brand: Maytag Model Number: MGDC400VW0 Main Symptom: stops heating after 3-4 cycles, but keeps running and doesn’t stop. Keeps blowing the thermal fuse What happens & when: the dryer will run good for 3-4 cycles with heat and then it blows the thermal fuse. When the fuse blows, the dryer keeps running and the timer does not advance and it blows cool air
Error Code (if any): none
Parts or tests already tried:high limit thermostat, cycle thermostat, thermal fuse, cleaned out around blower fan.
On your Maytag MGDC400VW0 gas dryer, the fact that the thermal fuse keeps blowing after three or four loads tells us that the dryer is likely overheating. Since you’ve already replaced the cycling thermostat, high-limit thermostat, and thermal fuse, I would concentrate on airflow and burner operation before replacing any more parts.
The dryer continuing to run without heat after the thermal fuse blows is consistent with a gas dryer where the fuse interrupts the heating circuit. In the automatic drying cycle, the loss of heat can also prevent the timer from advancing normally.
What I would check next
1. Exhaust vent restriction
Even though you’ve cleaned around the blower wheel, check the entire exhaust vent from the dryer to the outside of the house.
Check for crushed or kinked venting behind the dryer.
Check for lint buildup throughout the exhaust duct.
Make sure the outside vent flap opens completely.
Wash the lint screen with warm, soapy water to remove any dryer sheet residue.
Restricted airflow is the most common cause of repeated thermal fuse failures.
2. Blower wheel
Unplug the dryer and shut off the gas supply.
Check that the blower wheel is tight on the motor shaft.
Look for cracked or damaged blower fins.
Make sure the wheel cannot rotate independently of the motor shaft.
Inspect the blower housing and lint chute seals.
A blower wheel can appear perfectly fine but slip on the motor shaft when running.
3. Check the replacement thermostats and fuse
The correct components listed for your model are:
Thermal fuse: WP3392519 — opens at approximately 196°F.
Cycling thermostat: WP3387134 — rated at 155°F with a 25°F differential.
High-limit thermostat and thermal cutoff kit: W11050897.
Blower wheel: WP694089.
Coast Appliance Parts+2
Make sure the thermostats are mounted flush against their housings and that all electrical connections are clean and tight. I would also recommend using genuine OEM thermostats and fuses.
4. Check the exhaust temperature
Once the airflow has been verified and the failed fuse replaced, have the dryer tested with a temperature probe in the exhaust airflow, with the gas dryer safely vented outdoors.
Run the dryer empty on Timed Dry, High Heat.
The expected cycling temperatures are approximately:
Burner shuts off: 155°F.
Burner comes back on: 130°F.
If the temperature continues climbing toward 196°F without the burner shutting off, the cycling thermostat, its wiring, or the burner control circuit needs further investigation.
These are expected temperatures based on the thermostat rating; I have not verified the exact model-specific temperature testing procedure.
5. Check the timer operation
If the timer advances normally in Timed Dry but not in Automatic Dry after the heat fails, the timer itself is probably not the problem. The owner’s manual confirms that the timer advances differently depending on the cycle selected.
ManualsLib
A few questions
Have you cleaned the entire exhaust vent all the way to the outside?
Were the replacement thermostats and thermal fuse genuine Whirlpool OEM parts?
Is it the thermal fuse on the blower housing or the thermal cutoff on the burner housing that keeps failing?
Does the dryer cabinet feel unusually hot before the fuse blows?
Does the timer stop advancing in both Timed Dry and Automatic Dry?
My primary suspicion is restricted airflow or a loose blower wheel. I would rule those out before purchasing a timer or any additional electrical components.
Do not continue replacing thermal fuses and running full loads without identifying the cause. The fuse is a safety device protecting the dryer from overheating and a potential fire. Never bypass it.
