I washed something I shouldn’t have and it tore up the rubber boot seal on my Maytag 3000 Performance Series Front load washer. Am looking for the part numbers and directions from the manual of the step by step process to replace the seal. I don’t want to take apart anything that doesn’t need to be taken apart.
I really appreciate your help!
Thanks, Kris
The parts numbers are on this page here
Door and latch parts replacement parts for MAYTAG MHWE300VW13 AUTOMATIC WASHER | AppliancePartsPros.com
In terms of instructions, see if the tech notes that are under the top or inside the lower service panel are helpful. Maytag no longers allow access to its tech data, so I cannot link you to any instructions but see if this manual for a Whirlpool Duet is close enough to help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
