Maytag fridge side not cooling
Fridge slowly started to get warmer. Found a lot of dirty lint like build up in the condenser and compressor area. After a couple of hours the freezer temperature was still under -18 celsius but the fridge side seem to be stuck at 11 degrees celsius. This is a Maytag RSD22A side by side refrigerator freezer unit.
I did not check the temperature on the freeze before the clean up but it seems like that side was not noticeable affected.
Not freezing green light on bottom door is blinking
