Hello I have a maytag French door style and the display panel is not working the fridge is not working not cooling but the light inside is working and when you press the handle like you trying to get ice or water the panel beeps very loud and all the lights on the panel come on it displays the number 888’888.
Can someone help me please thanks in advance:confused:
Have you tried unplugging it for a few minutes to see if it will reset?
Also you are missing the last digit of the model number.
Thanks for replying MFI2569YEM0
And yes I unplugged it for 30 minutes and plugged it back and same problem I also unplugged overnight plug it back in the morning same problem
Parts for Maytag MFI2569YEM0 / Refrigerator - AppliancePartsPros.com
Try to get into diagnostics.
Also check the connections.
MFI2569.pdf (262.9 KB)
