Water sprays out of the top of the refrig. The fill tube is probably frozen but why? The refirg. section also freezes things and there is frost in the baskets in the freezer. Are there symptoms connected? The gaskets are good a nd doors close ok. Any help will be appreciated.
The fill tube may freeze when the water fill valve does not fully close, allowing water to seep in to the tube and freeze.
Fridge section freezing things is another issue.
