Maytag french door frig
Purchased Maytag French Door/Bottom Freezer Model # MFI 2269VE 6 years ago. The lights inside still work, but the front display is blank and neither refrig/freezer work (except for lighting-no cold) After reading the forum, we purchased a HV control board however we cannot get the display to correct. It currently reads PE 0000. We have tried the code programming instructions that we found on here but cannot get the digit value’s to change the code. In program mode, it displays PE0000. When we press the refrigerator temperature control buttons, it changes from ICE to H2O, but does not change the digits. Would appreciate any help at this point.
https://www.boardbusterz.com/single-post/2017/02/03/Your-Maytag-Side-by-Side-Display-Flashing-or-Completely-Dead
