I have a Maytag Freezer Model # - MQF1656TEW01. I bought it brand new at Home Depot in June 2012.
Problem – Since last week, it has not been cooling (at all), not to mention freezing which is supposed to.
Observation –
Outside -
- The compressor is working, as well as the start relay. I can hear the compressor picking up.
- I can also feel that the evaporator pipe is cooling, by touching it.
- The condenser coil at the bottom is clean.
Inside - I opened the fridge & removed the cover at the back - - The light is working & the temperature control thermostat is working as I rotated it from end to end, it turns off the compressor & minutes later, rotated it & the compressor turns on.
- The condenser fan motor is working ok.
- The evaporator coils are normal (neither cold nor hot) & NO ice on it.
- The evaporator pipe inside the freezer that connects to the evaporator coils is ice over (frozen ice on the pipe that connects to evaporator coils)
- The freezer door gasket is in excellent condition
Test –
I went to Maytag website to read what other users of this freezer model are experiencing at – http://www.maytag.com/kitchen-1/refrigeration-2/refrigerators-3/-[MQF1656TEW]-1102175/MQF1656TEW/ - I found out (from the website) that the main problem with this freezer model is the defrost timer/thermostat (if not advancing will not turn on the defrost heater, thereby causing icing over the evaporator coils & air will not travel through the coils to provide cooling)
- I unplugged the defrost thermostat & test the defrost thermostat for continuity. From my test meter , there was no continuity of the defrost thermostat. I then put the defrost thermostat on ice, for it to reach the low temperature of its operating range, redid the continuity test, there was no continuity reading.
- I went to AppliancePartsPro website to look for the freezer model & parts at – 03-Unit Parts parts for Maytag MQF1656TEW01 / - AppliancePartsPros.com
- On 12/26/13, I placed an order (Order No )for the defrost thermostat – Bimetl-Def (Part no AP4539435 from Whirlpool) for a total cost of $34.88 ($27.93 + $6.95(shipping)).
- I received the Bimetl-Def part on 12/28/13. I tested the ordered part as I did on no 3 above, there is no continuity reading on it. I installed the new part in the freezer. Unfortunately, it makes no difference to the freezer not cooling. I re-tested the ordered part as I did on no 3 above, there is no continuity reading on it.
NEED HELP - Can you help me identify the correct part based on my Observation & Test.
- I assume the Bimetl-def I ordered is defective but you can confirm.
- I will need a Return Merchandise Number to return it & the address where to return it to.
heather: everything I’m reading points to the same thing, what I would suggest is to go on our site and post a question and list everything you have for me in this chat, one of our technicians will respond within 24-48 hrs.
heather: I can go ahead and do the return now if you would like.
LANREO: OK, Thanks for your help.
