Receiving error code f3e2 have replaced ccu and still receiving code. need help i have tested ntc sensor seems good. thanks John
Receiving error code f3e2 have replaced ccu and still receiving code. need help i have tested ntc sensor seems good. Please can someone help us been waiting to hear answer thanks John
In my case, and couple of others here on forum, problem was a broken wire between the sensor and the CCU unit.
In the rear behind and below the tub enclosure, the sensor wire was attached to the tub and then joined another bundle of wires at a wire tie.
At that tie, the tub vibrations had flexed the wire until it broke, first inside the wire’s insulation so the F3E2 was intermittent, and then finally breaking the insulation also, so F3E2 became permanant.
