Brand: Maytag
Model Number: mer6765baq
Main Symptom: oven not preheating properly
What happens & when: lower oven preheat
Error Code (if any): none
Parts or tests already tried: turned off, took off back panel, ran cleaning cycle
I was trying to bake a pie and the lower oven wouldn’t preheat to 450. (The upper oven is fine.) The lower element comes on, but not the upper element. Broil works fine - upper element is on. Ran a cleaning cycle and it looks like both elements work. Then I tried preheating to 475 and it worked.
It looks like both elements work but the preheat cycle isn’t using the upper element. Is it a bad relay or control board? Thanks for any help.
