dryer heats but no drying of cloths possibly blower out, yes, maybe, I don’t know.
Replacement parts for MAYTAG MDE2500AYW DRYER- ELE | AppliancePartsPros.com
I doubt the blower is shot as this would blow a thermal fuse.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer’s vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
