Maytag Electric Dryer
My dryer works for the first load and after that on the second load and the loads after, it trips the house breaker every 10 minutes. Where should I start trouble shooting the element or the drive train?
Initially, it sounds like the element is heatin up, expanding, and then part of it is grounding to the chassis.
Could also be that the breaker is weak.
