Maytag electric dryer performa
No heat and drum doesnt turn Remove door switch & tie 1red wire &2 white wires together and everything works fine . door switch is new & ive bypassed all sensors I can find. whats wrong
Check the thermal fuse (#5 on the diagram) for continuity.
  • The thermal fuse/high limit thermostat kit AP4242472
Here are the breakdown diagrams and Replacement parts for MAYTAG PYET444AYW Dryer - Ele | AppliancePartsPros.com
