Maytag dyer
when i push the to start it wont come on just clicks
r Pics
 To get to the heating element on most of these dryers you remove the back dust cover:
[LEFT][/LEFT]
[LEFT]1. Hi Limit (small limit upper right hand side of this pic) [/LEFT]
[LEFT] the most frequent problem if dryer RUNS but no heat. [/LEFT]
[LEFT]2. Heater assembly. 7. Control thermostat(s).[/LEFT]
[LEFT]5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element
(if you do not have a meter remove and inspect this heater coil for breaks).[/LEFT]
[LEFT] [/LEFT]
[ATTACH]1442[/ATTACH] A betta look at dat fuse:D
fuse whlp.jpg (1.6 KB)
