I have a Maytag Performa dryer, the dryer was running and suddenly stopped and there was a burning smell, I changed the heating element and the thermal fuse with no luck. Whats next. Thanks
Hi.
First of all check if there is 240VAC at the dryer’s disconnect block at the back, be careful if you don’t feel comfortable to work with “hot” appliance just try to reset the circuit breaker.
With unit unplugged:
Next, check the door switch for continuity between two contacts with wires on them (remove one wire off when checking).
You should read continuity with door closed and infinity with door open.
The switch AP6009635
Switch is good? Next check continuity at the motor contacts between PURPLE and WHITE. No continuity - replace the motor AP5272116
If both above mentioned parts are good - replace the timer
[AP6009645](http://www.appliancepartspros.com/whirlpool-timer-wp53-1810-ap6009645.html)
Here are the breakdown diagrams and 05-Motor & Drive parts for Maytag PYE2200AYW - AppliancePartsPros.com
Post the results.
Simon.
