My dryer smelled like it was burning so I took it apart, cleaned it out and put a new belt on. That didn’t seem to fix the problem so I took it apart again and took the motor out. The shaft was so hard to turn so I assumed that I needed a new motor. I went and put a new motor in it and noticed that there was a black wire that was previously attached to the left lower side of the heat housing. It looks like it connects to the heating element. The wire looked like it was burnt so i put some electrical tape on it and plugged it back on. Put everything back together and it worked on one load of clothes but when I took those out they seemed too hot( it didn’t seem normal). Put another load in and checked on those and there was no heat at all. Took it apart again and noticed that the black wire was burnt again leaving the metal fastener still attached to the plug and the wire was completely unattached. I don’t know what to do, can you help me, please?
Something is causing too much amp draw. Gas or electric?
Seems like a safety would kick out before burning a wire unless the wire just has a poor connection. Makesure connections are clean and tight.
Also, check for obstruction in the vent line. This can cause an overload situation.
[COLOR=#0000ff]http://www.upthemileage.com[/COLOR]
[COLOR=#0000ff]http://www.appliancerepair-shiawassee.com[/COLOR]
Replacement parts for MAYTAG MDE7500AYW DRYER- ELE | AppliancePartsPros.com
See the attachment for a manual.
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.com
You will have to join the site to download the manual but it is free and has lots of info for the appliance DIYer.
Unplug the unit and check the cycling thermostat and the high-limit thermostat with a meter both should be 0 ohms.
Then check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
This may have contributed to the wire burning out.
This may have been your problem and it has now burned out the heating coil or a thermostat.
Now for your original problem.
Just taping up the wire would not have fixed the problem as you have seen.
If you have a dirty or pitted connection it is a resistance. So when current passes through it heat is generated basically that is how a heating coil works.
This causes more pitting etc., which increases the resistance which increases the heat and so on and so on till the connection fails.
You will have to cut back the wire till you get to nice clean copper and the attach a new connector. Be sure to use one rated for high current.
From the sound of it I would also replace the heating relay.
Thank you so much for the quick replies. I will try all of these suggestions. My husband told me that I couldn’t fix the dryer and that he would take care of it this weekend. So…now I’m bound and determined to do it on my own! (With your help…of course) I’ll let you know how it works out.
Sorry to be a bother but what number is the cycling thermostat on the parts list. I found the hi-limit thermostat but I don’t see where the cycling thermostat is. Thank you again
I think that the cycling thermostat is an error.
Does not make sense to me that it would have one as it uses a thermistor to sense the temperature. Then the board runs the heater relay to cycle the temperature.
