dryer works well but squeeks like a fan belt slipping in a car. Replace belt, idler pulleyand front glides but did not fix the problem. Rollers seem ok. Any clues what else might be making that kind of noise?? Kris.
It could be the motor. You can run just the motor on air dry cycle with the drum out to see.
You could also try and put some WD40 on the drum rollers. Often times they are ok, just a little dry.
