Maytag Dryer will not start
My dryer will not start. THe light comes on but nothing happens when you push the button to start. I have checked the breaker. All is good there. What else could be the problem?
The first thing I would do is check the thermal fuse (#6 on the diagram) for continuity.
If this fuse is open then you have to replace the high limit thermostat as well.
  • The part number for the thermal fuse AP4048636
  • The part number for the high limit thermostat is AP4298584
Here are the breakdown diagrams and Replacement parts for MAYTAG MDE3706AYW | AppliancePartsPros.com
