Maytag Dryer Repair
[COLOR=#000000][FONT=Times New Roman][SIZE=3]I need to replace the [/SIZE][/FONT][FONT=Arial]Blower wheel assembly[/FONT][FONT=Arial] Part Number: AP3992539 made by MAYTAG[/FONT][FONT=Times New Roman][SIZE=3], a part of the Motor Drive. [/SIZE][/FONT][/COLOR]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]When the dryer spins, it makes a tumble noise. I opened the front panel and the noise comes from the Motor Drive. If I turn the dryer’s drum, it makes the noise with every revolution of the drum, but does NOT come from the drum rollers or the belt. [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]1. Does it sound like the blower wheel assembly needs to be replaced? [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]2. Can you provide a service manual or removal and assembly instructions? [/COLOR][/SIZE][/FONT]
They should have info at the web site www.applianceaid.com Remove front panel and blower housing cover, then remove “C” clip and clamp from the motor shaft.
