Maytag Dryer Permanent Press Cycle
Dryer puts out heat normally, however, during the permanent press cycle there is no cool down. Replaced both hi limit thermostat (330396) and another thermostat (306911) and didn’t correct problem. Duct is clean. Any help is appreciated.
The thermostats do not control this, try replacing the timer.
If you buy from this site and the part does not fix the problem you can return it if you meed certain conditions. See the returns policy for details.
Success. Problem Fixed. Replaced the timer. Thanks.
Great, glad to hear it and thanks for updating us.
