Brand:Maytag
Model Number:MED6630HW0
Main Symptom:no heat
What happens & when: sometimes the dryer heats…sometimes it does not.
Error Code (if any): no
Parts or tests already tried: I have a Maytag Dryer, MED6630HW0. Several months ago it stopped heating, otherwise it ran fine. There are no errors on display.
Circuit breaker appears to work fine (not “tripped” and does turn dryer on/off)
Outlet tests correctly
Cable connection to dryer tests correctly
Inside the dryer
Heating element and heater box:
Heating element has continuity between the two terminals and no continuity between either terminal and the body (ground).
Thermal cut off and High Limit Thermostat (both on heater box) have continuity between the two terminals and no continuity at either terminal and the heater box (ground) .
Blower housing:
Thermal fuse has continuity between the two terminals and no continuity at either terminal and ground.
Thermistor has about 15k Ohms of resistance and drops very quickly when heated with a hair dryer.
When I put it all back together….it worked fine, until several months later (now). It is back to running as expected but no heat. I took everything apart and everything tested as before.
I entered the diagnostic mode; there are no error codes shown and there are no errors stored.
In the encoder test, all keys work as expected. They turn off as I press each key.
The automatic test cycle appears to run correctly, except there is no heat. It runs with “Enc” displayed for several minutes, then “but” displayed for several minutes then turns itself off.
After putting it back together, the dryer runs and sometimes heats….sometimes does not.
Is there a wire coming loose that I just tightened after disassembling (although, I made sure to push all connection together well), did I not test a component properly, or is there something else wrong?
Thanks for thoughts/suggestions
